Philips AG-9018
chm
Re: Philips AG-9018
Message par chm »
Bonsoir Edouard
Je ne sais pas ce qui se passe au niveau de l' ampli,
mais je veux juste te dire que l' ampli est réparable, ce qui n' est pas probablement
le cas des HP, prends soin des enceintes, donc de l' ampli.
Christophe
Edouard-
Re: Philips AG-9018
Message par Edouard- »
Salut Christophe.
C'est pour ça qu'il est débrancher. Je vais le re-brancher sur des enceintes 8 ohms et voir ce qu'il ce passe. Si ça marche pas. Ba soit je m'acheter un testeur ESR et je vérifie tout les condo. Soit ba, je ne sais pas :lol:.
Edouard
Diego72
Re: Philips AG-9018
Message par Diego72 »
Hello everybody,
It's Diego from Italy.
I have an ag 9018 too.
Some days ago a speaker don't play no more music, but it is an ampli falut and not a loudspeaker damage.
Now I disassembled the ampli and I found a condo broken ( some chimic element was exit from it).
Now I have to buy it but I don't know what to buy.
May you help me in identifing a good replacement for it?
thank you in advance for any help.
Faithfully.
diego
The condo have writed inside
SP-CR
SCP
100/50
174+
Here the image of condo
Here where i extract the capacitors from the chassis
Diego72
Re: Philips AG-9018
After many days the two condos arrived and I have replaced them.
Well I have Always the same problem the line of a speaker work the other don't work.
Do you have any idea what i can check before bring it to a guy could make it working again?
Have a nice time everybody and thanks for any help.
Diego
chartz
Re: Philips AG-9018
Message par chartz »
Hi Diego,
This is a French speaking forum you know!
You won't have many readers if you post messages in Frenglish as you do.
Contact me if you'd like me to translate your messages before you post.
Otherwise I can recommend the excellent http://www.vintage-radio.net/forum/
Jacques
Maxime1123
Re: Philips AG-9018
Message par Maxime1123 »
Hi Diego,
Questions about out of order products can be asked in the "en panne" part of the forum ; maybe some of us will have some answers for you. There are many other usual rules to know about the forum, I hope you can read french easily. Otherwise as Jean said, there are also great English or Spanish speaking forums to recommend.
Just ask.
doum
Re: Philips AG-9018
Message par doum »
Salut
Je déterre un peu ce sujet et y ajoute quelques photos internes de mon AG9018.
J'ai remplacé tous les tubes et les condos chimiques.
doum
Re: Philips AG-9018
Message par doum »
L'ensemble complet:
Re: Philips AG-9018
Superbe ampli et ensemble tout aussi beau; bravo Doum :genial:
JL
Petitloup54
Re: Philips AG-9018
Message par Petitloup54 »
En 800 ohms, cet ensemble est magique 👍
