Belle acquisition, j'ai de très bons souvenirs d'écoutes avec ce bras, il ne devrait pas dépareiller dans ta collection et ne se fera remarquer que par sa couleur!
Fidelity Research FR-66fx
- vendin
Re: Fidelity Research FR-66fx
Pascal.
quoler
Et effectivement c'est bien l'expression appropriée je pense.Klemp a écrit :quand l' une se présente, faut pas mollir .. !!!!
60-70's rock
Tiens ? Quelque chose qui ressemble à un bras de lecture...
Et une boite contenant certainement une belle cellule... s'agirait il de celle-ci ?
Quand au FR66fx, c'est effectivement un bras extrêmement musical apprécié également en sud-ouest. Le mien se fait vieux... mais fonctionne toujours parfaitement.
En effet, et on se demande bien pourquoi.Un des bras les plus recherchés au monde !
- Klemp
Petit commentaire intéressant extrait d' un site Japonais spécialisé dans les produits de haute qualité.
The most famous tonearm that Ikeda-san made is FR-66S but the best one is FR-66FX.
FR-66fx is long version of FR-66S, the armward 's sharp is not same as FR-66S, it is in "banana" sharp, same as EMT 997 tonearm. Armward was made from special aluminium alloy. All part except ofarmward was made from gun metal, black polish, Mr Ikeda designed this tonearm for light weight cartridge, it can handle stylus pressure up to 3g, dynamic balance But it is best matching with SPU-G which is low compliance cartridge, It is also match with DL-103 series cartridge.
Ikeda told that FR-66S is his best product but many audiophile gave to FR-66fx higher reputation. That is reason why FR-66fx now is very very hard to get, it is even harder than FR-66S even through price of FR-66fx is not as expensive as FR-66S.
As Ikeda foundered Ikeda Sound Lab, he made an new tonearm IT-407 and IT-307 and IT-407 was developed based on this FR-66fx tonearm not FR-66S.
Due to order of customer, I did overhaul on this tonearm. My customer want to use this tonearm same as FR-66fx PRO, no need anti-skating, rewire with a bigger wire of Mogami 5248. After rewiring, it will be come FR-66fx Pro, using for cartridge has stylus pressure higher than 2g. As you use cartridge with pressure higher than 2g, you dont need anti skating. Many audiophile dont like anti-skating because it make sound worst.
I also did maintenance, readjust stylus pressure mechanism, cleaning all part one by one, As you use dynamic balanced toneram, stylus pressure will become not accuracy after times and you need to adjust it.
You can see in the picture that stylus pressure of this tone arm is nearly same with Empire 98 tonearm, I think Ikeda designed this one based on the design of Empire tonearm.
Final test: Tonearm is tracing perfectly on record without anti-skating. Sound is deep with beautiful of bass sound. It seems that removing the anti-skating make sound deeper and musical but the detail is not better than original. The sound is very well balanced and dynamic in overall with new upgrade.
- Klemp
Cela a pris du temps mais ça y est, il est installé ... dans un premier temps avec une cellule Fidelity Research FR-7, bobine mobile très raide tout juste plus qu' une DL-103 et équipée d' une bobine sans noyau (ni pépin) et d' un diamant VdH ....
Comme la compliance est très basse, j' ai monté sur le bras un accessoire Final Audio Research pour augmenter l' inertie et contrarier tout mouvement parasite de la cellule sur forte modulation.
Elle est reliée à un transfo Fidelity Research FRT-3G sur impédance basse de 3 ohms (résistance de bobine 2 ohms) par l' intermédiaire d' un câble de modulation d' origine Western Electric-14AG de 1940.
C' est une cellule que j' ai essayé sur de nombreux bras ... Stax, SME, Dynavector... et à chaque fois j' ai détecté de grandes qualités avec une dynamique de folie, beaucoup de présence et d' informations mais une brillance désagréable dans les hautes fréquences.
Sur le FR66 ce défaut disparaît pour laisser une précision de restitution incroyable à tel point, qu' ainsi installée, elle concurrence sur tous les plans des cellules modernes et récentes comme l' Ortofon Cadenza Blue sur un Dynavector DV-507.
- Petitloup54
Je suis toujours aussi impressionné par ta table de lecture équipée de 4 Bras légendaires
Le Fidelity Research est vraiment splendide.
- babaas
C'est assez "marrant" car on associe généralement le FR66S plutôt que le fx avec les cellules à compliance basse.
Comme quoi.
Comme quoi.
- Klemp
C' est vrai et c' est pour cela que j' ai adjoint au 66fx le petit accessoire de chez Final AR conçu pour autoriser cette transgression
- babaas
Je ne connaissais absolument pas cet accessoire.
Toujours est-il que le FR-66fx reste une véritable légende.
- Klemp
Après montages d' une petite panoplie de cellules dont Ortofon SPU-G de 1959, SPU-Gold de 1985, EMT XSD-15 VDH, Dynavector DV 17D3, quelques cellules Fidelity Research et une Supex SD-900 Super VDH, c' est avec l' Ortofon Cadenza Blue que j' ai obtenu les résultats les plus "probants" mais de manière générale le FR-66 apporte une précision de lecture qui se traduit par un message plus clair, moins brouillon dans les fortés, une image Stéréophonique également plus stable, un grave plus soutenu et une dynamique qui "claque" sans faillir.
Il dépasse le Dynavector DV 507 sur les derniers critères et est plus "universel" dans l' adaptation aux cellules que les SME 3012 et Stax UA-70.
En attendant une petite nouvelle, quelques vues avec la Cadenza.
- 4 Réponses
- 2090 Vues
Dernier message par Klemp
- 24 Réponses
- 88161 Vues
- 8 Réponses
- 36137 Vues
Dernier message par 6336A
